    Jun 2008
    Default Problems with Minwax stain
    So, I screwed up and failed to wipe off the excess stain after applying it to the wood borders on the doorways and the baseboards. now i have this wood that has a bit of a glossy sheen to it and I'd like to somehow remove the glossiness. Does anyone have any ideas? do I need to sand it all off and restain?
    thanks!
    KC
    7,865
    Default Re: Problems with Minwax stain
    If this was a "stain only" product, read the label and follow the directions for cleaning up dried product. Generally, mineral spirits (paint thinner ) will soften and remove excess surface material. If this is a one step "poly-stain", again, read the label for dry clean-up recommendations, though my experience with poly's in general says that you'll be hard pressed to remove dried excess with anything short of sanding.
    Hope that helps.
    5,998
    If it's a Minwax stain/finish all in one, let it dry throughly and buff with 0000 steal wool and the vacuum throughly.
    Jun 2008
    Thanks for the advice. i'll update after i'm finished.
    K
