Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    6,063
    Default Re: Tonge and Groove Porch in the elements
    By the way, another way to put the plywood between the joists if you don't want to rabbit the joists is to nail 1X1 on the sides of the joists " down from the top edge of the joists.
  2. #12
    Jul 2008
    One question why did they build basements under the fornt porch? I have the same problem but would like to keep the tongue and groove decking. Thanks.
  3. #13
    May 2014
    How did you end up handling this issue? I recently bought a home that has the same issue. I also literally have no door threshold so not sure I can spare moving the door up that much without hitting the header.
