Closed Thread
Thread: Squeaky Floors
    Unregistered Guest
    Default Squeaky Floors
    I just saw an episode where Tom fixed a squeaky floor with the use of a special drill bit that can go thru carpet and another device that blocks the screw from penetrating the joist. I did not catch the name of the device, the drill bit, and the break away screws can I get this?
    Unregistered Guest
    Default Re: Squeaky Floors
    Check the product out at www.sqeaknomore.com. I have seen it in ACE Hardware stores.
    Unregistered Guest
    The correct spelling is www.squeaknomore.com.
    Jul 2007
    I have used this product and it works very well so far. It was very easy to use as long as you are able to locate the studs.
