Results 1 to 10 of 16
    Jun 2008
    6
    Default Toilet wont flush
    The toilet won't flush when I push the lever down. The water does drain down, but the cycle doesn't complete. The bowl fills back up without flushing. The flapper takes awhile to reset and the overflow tube fills up with water when flushed. Any ideas?
    G
    Default Re: Toilet wont flush
    If you mean the bowl doesn't empty ... I would start by using a plunger or a closet snake to try and free the obstruction that may be present.
    Perhaps small childern that have have dropped a toy into the toilet?
    Jun 2008
    6
    A small child did drop some toilet paper into the tank, not the bowl. I emptied it out as best I could but I believe that there is still some in there. It took numerous flushes to get the toilet to flush and it did start working but has stopped now.
    Try this simple test ... get a container .... say 1 gallon of water .... pour it rapidly into the bowl.
    If the water in the bowl rises and doesn't drain .... then there is a restriction in the siphon trap of the bowl itself.
    6,941
    If canuk's idea checks out, the put a few drops of food coloring in the tank and flush again. Then watch the bowl for the colored water to evenly swirl down the sides. If you had toilet paper in the tank and it went through the system, then the holes under the lip of the bowl could be clogged, the colored water will determine if the holes are plugged.
    Yep ... that was the next thing.
    Jun 2008
    6
    Thanks. If pouring the water down doesn't work, do I need to use a snake to clear the siphon trap?
    If a plunger doesn't work then you could try the snake.
    Worst case scenerio is to remove the toilet to see waht's there and try and dislodge it.
    Jun 2008
    6
    Thanks for the advice. I'll try it tonight.
    You're welcome .... let us know how you make out.
