Results 1 to 10 of 10
Thread: screws
    Sep 2008
    24
    Unhappy screws
    I have not yet found a screw bit that fits a general purpose
    screw.#1 bit is too small.#2 bit slips most of the time.
    deck screws(along with the proper bit)work best,but still
    slip occasionally.
    I have a collection of rounded screws,and"rounded" screw bits.
    I am beginning to wonder if its just me.
    or is it?
    Jul 2009
    Northeast
    661
    Default Re: screws
    How long is the screw??? If it's a pretty long one like a 2-3 inch try rubbing the screw threads on a bar of soap. It acts as a lubricant and works awesome. Good Luck!!!
    8,065
    Default Re: screws
    It's tough to find decent tips anymore. The standard now seems to be a cross between a #1 and a #2 sized bit, the result is something too big for small screws and too small for big screws. The best tips reach to the bottom of the screw head and fills the opening completely. You'd think that would do the trick as well, but then the manufacturers go playing around with the tips being hardened or not as well as the quality of the steel the tip is made from. Too soft and they slip and strip out, too hard and they shatter.
    Of all the brands, I've gotten the most consistent performance out of DeWalt tips, though I've gotten plenty of those that weren't too good either.
    Sep 2008
    24
    Default Re: screws
    [QUOTE=Sten;122101]How long is the screw??? If it's a pretty long one like a 2-3 inch try rubbing the screw threads on a bar of soap. It acts as a lubricant and works awesome. Good Luck!!! [/QUOTE
    for most of my projects,I'm using 2.5 to 3" screws.lubing the screw sounds like an interesting idea.gotta try it.
    Amarillo, Tx.
    5
    Default Re: screws
    For me it is Bosch #2 ribbed tip bits. They grip well and are hard to shatter. I also use a Dewalt impact drill/driver. These choices come from extensive experience and literally thousands of stripped screw heads and and ruined driver bits. When possible pre-drill. Good Luck!
    8,065
    Default Re: screws
    Quote Originally Posted by HowardH View Post
    You're right, it's surprising how much the impact helps to drive the screw. I assume that you're using an actual impact driver rather than the "impact" setting on a standard drill, there is a big difference, the impact driver being the better of the two.
    Amarillo, Tx.
    5
    Default Re: screws
    The model I use is the Dewalt dc825 18v 1/4" impact driver.
    strictly an impact driver. Great tool.
    I don't use the 2 piece magnetic bit systems...they just won't handle the torc. Mine has a spring loaded detent to hold the bits. Of course you have to use the bits with the detent "slot".
    Jul 2009
    Northeast
    661
    Default Re: screws
    I use Ivory Snow or Tone, no pre drilling required
    Sep 2009
    florida
    598
    Default Re: screws
    Ive found EazyPower bits to last longer than any others on the market. Been using them for yrs.
    http://www.eazypower.com/shop/
    Gizmo
    Hidden Content
    Hidden Content
    8,065
    Default Re: screws
    Quote Originally Posted by Sten View Post
    And it helps keep your screws from getting smelly.
