    Default Corner tub doesn't match corner
    Hi,
    I have a dilemma. My corner tub does not sit flush with the walls in my bathroom. The gap gradually increased to about 1" at the ends. Any suggestions on how to fill that space? Should I set the tub flush against one wall and worry about a larger gap on the other? It is a beautiful Infinity tub from Aquatic and the tub sides are not straight they sweep from the corner down to the end.
    Thanks,
    chris
    http://www.aquaticwhirlpools.com/pdf/Infinity13-08.pdf
    Memphis, not Egypt
    183
    Default Re: Corner tub doesn't match corner
    Establish one wall preferably the straightest and set the tub against it. Then rip strips to fir out the crooked wall. Or straighten out the wall that is out of square. Hope it helps.
