    Michigan
    Default Where can I find a Patio Door seal?
    My patio door seal is all torn up.. I just noticed this winter when the wind was whistling in from the top and the bottom. It is an interior door that leads into a 3 season's room so it wasn't terrible but I can't afford another winter..
    where on earth can you find a replacement seal for a patio door? I've searched ****** for days, no luck, I've been through Home Depot, Lowes, Menards and Ace hardware... no luck.. the door is old and you can't read the manufacturer information but it appears to be just a standard patio door, nothing special, double pane glass, it looks like low E..
    Any ideas anyone?
    thanks!
    Upstate NY
    34
    Default Re: Where can I find a Patio Door seal?
    If you could post some pics of what the old stuff looks like or at least where it goes I might be able to help.
    Jul 2008
    7
    I have the same issue, just installed some "new to us" sliding patio doors, & unfortunately the seals between the jamb & door were removed before we got the doors. Doors otherwise in great shape, they were on their way to the recycle yard when we saved them.
    Theyre Alcan doors, & I need the T shaped seal that slides into the aluminum side jamb. Im guessing its made of vinyl, the part that slides into the jamb is 5/16 wide, & the whole seal is high.
    Ive searched locally & on the web & havent found a thing.
    Ideas?
    Thanks!
    Lee
    Upstate NY
    34
    This is the best I can do with out pics. Try this site.
    http://www.conservationtechnology.co...atherseals.pdf
    Jul 2008
    7
    Thumbs up Re: Where can I find a Patio Door seal?
    I found that site, no joy there.
    Here's a couple of pics of the 1 seal I do have.
    Narrow part of the seal slides into the jamb, & the long part seals up against the door. 2 per, one on each side of the door.
    Thanks!
    Lee
ID:	1445   Click image for larger version.
