Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Lakeland ,MN
    Default Re: grounding an ungrounded outlet
    Ravens, I think one flaw in your post is that you are assuming that the wrap wire is grounded, and with the old wiring that the OP described it probably isn't.
    Jack you are right I did assume the grounds were grounded. Thanks for pointing this out.
  2. #12
    Bad Axe, Mi
    For the most part, they are not grounded. I checked. I was able to ground the two that were grounded. These two must have been installed at a later time. I am assuming, then, that unless I am able to run a ground wire, the others will just remain as they are...ungrounded. Thanks for the help one and all.
