    Question bad cast-iron pipes!
    I tore the basement floor up and removed the old cast myself.Now i need to know how to tie into the cast with pvc is there a special fitting?
    Angry Re: bad cast-iron pipes!
    what does nikey got to do with cast-iron or pvc pipe nothing!!!!!
    Baltimore, MD
    76
    Default Re: bad cast-iron pipes!
    I don't know where the shoes fit in
    But I once did this very unintentionally. In my 1920's row home I needed to open the drain to clean out a clog... and while trying to get the cap off with my pipe wrench, the whole drain pipe crumpled and came apart.
    I'm no plumbing expert but fortunately my Dad is... he dug into the floor until he found a reasonably stable piece of pipe. It's been many years but as I recall he used some sort of PVC coupler that had a rubber sleeve and metal clamps and tied that into the existing drain. From there he re-piped up with PVC.
    I know that's not much but maybe it will point you in the right direction.
    Yep .... the forum is under a spam attack.
    As xyxoxy mentions there are couplers for this purpose .....
    http://www.fernco.com/1056.asp
