Results 11 to 20 of 21
  1. #11
    Default Re: power but yet no power.....
    Sounds like it's time to call in an electrician.
  2. #12
    NW Florida
    11
    I have just about given up....just wondering if maybe I should be running 12 wire and a different amp breaker and if so, what ampage???
  3. #13
    42
    Any splices in the wire ? Does any of it run underground or out of sight , such as in conduit ? I still think there is a bad connection SOMEWHERE or a damaged wire . Possibly a bad breaker either at the source or the sub panel .
  4. #14
    42
    Quote Originally Posted by busladyred View Post
    #12 wire would be more desireable , but it's not the cause of your present problem .
  5. #15
    New Jersey
    20
    sewing machines... air conditioner....14/2...30 amp breaker
    shut the breaker off. Call an electrician. Your in over your head and you have crossed the line well into dangerous. GET HELP
  6. #16
    The deep South
    459
    Quote Originally Posted by lmills148 View Post
    Yep , probably the best thing to do . Something is going on that's not obvious and further troubleshooting skills are needed .
  7. #17
    6,055
    With a 30 amp breaker you should be using 12-2 plus ground. No you can not use 14-2 to the lights or recepticles, the breaker should match the smallist size wires in the circuit. You said you checked connections, did you check both the hot lead connections and the neutral lead connections? Did you install the light switch so it cuts power to the outlets by mistake? Do you have part of the circuit wired in series rather than parallel? If you can't answer these questions then it's time to call in someone who can.
  8. #18
    Shamokin, Pa.
    645
    Time to call in a pro....
  9. #19
    Chicago, IL
    162
    Negative...
    14-Ga wire = 15-amp breaker
    12-Ga wire = 20-amp breaker
    10-Ga wire = 30-amp breaker
    Those are minimum wire sizes.
    HTH
    Dave
  10. #20
    6,055
    Quote Originally Posted by Dave357 View Post
    Negative...
    Good catch Dave, I guess my fingers weren't watching what I was typing.
