    Sep 2007
    North Carolina
    19
    Question Copper bonding agent
    First I'll admit, I'm not too good at soldering copper pipes. Not being able to get the water out mostly. But I saw something called "Just For Copper". Claims to bond rigid copper and brass. Rather than burning my house down trying to solder in confined spaces...(an access panel in a closet..for example) I thought I might give this stuff a try. Has anyone tried it or had any luck with it..?
    Oct 2007
    9
    Thumbs up Re: Copper bonding agent
    I wouldnt dare use anything of the sort. If your afraid to solder than use the "Sharkbite" fittings and copper inbetween. I sell a lot of these fittings at my supply house. Just make sure the copper pipe is clean and free of burrs before using the sharkbite fittings, then your DONE
    The deep South
    459
    Default Re: Copper bonding agent
    What is a " Sharkbite " fitting ?
    Never mind . I did a Google search . Never saw such an animal .
