    Default new electrical, audio and videop wiring product
    recently show a demonstration on TV in passing, about a flat paper thin electrical wiring system in which you peel off the back stick to the wall and plug in and can run to any electrical outlet, audio system or video system and can be painted and it lays as flat as a sheet of paper... on constructive in look and appearence.. any body know what this product is...
    Smile Re: new electrical, audio and videop wiring product
    Aloha darduser,
    I would only run low voltage equipment on the lines. I think I saw the same thing on some HGTV show. It was designed for low voltage lighting.
