    6
    Default sun damage to vinyl flooring
    Our kitchen receives direct sun through the glass sliders. The heat from the sun has caused our white floor to turn brownish-red in areas. It is especially bad under area rugs. We also have a kick heater under the kitchen cabinets which blows warm air. That area is also heat damaged.
    We would like to install a new floor, but want a type of flooring that would not get damaged by the sun. I would appreciate any suggestion. Thanks
    6
    Default Re: sun damage to vinyl flooring
    Thanks. It does help
