    Default Need Help with Light Fixture
    I live in a 1950s house. It has 1950s wiring in it. I want to replace the old light with a new one. The new light fixture produces 134 degree Fahrenheit of heat. Will the new light fixture start a fire if I install it?
    Sep 2009
    Default Re: Need Help with Light Fixture
    I think we'd all need details on the new fixture? Is this a recessed fixture that is in contact with the surrounding building materials?
    The wiring should not be a huge issue, assuming the insulation on the wires is intact and not flaking apart.
    Dec 2009
    Alpharetta, Ga
    55
    Yes, you will have problems. The old wire is not rated for the new fixture. You will need to use a different light or change out the wire.
    Dec 2009
    Casper, Wyoming
    159
    That sounds way too hot. A clear fire hazard. Make sure to correct it.
    _______
    Find licensed electricians in your area.
    Quote Originally Posted by punintended View Post
    I agree --- more information about the fixture.
    If it's a flush mount enclosed fixture then it may be an issue.
    If it was a pendent enclosed fixture then it likely wouldn't be an issue.
    Shamokin, Pa.
    645
    Quote Originally Posted by cullen51 View Post
    What exact type of "1950s" does the house have?
    And just wondering how you know the new fixture will produce 134 degrees F?
