    Default Remove backflow preventer
    Greetings,
    I have a backflow preventer attached to my outside hose bib. When the water is running, it leaks slowly so I'd like to take it off.
    I used an adjustable wrench and the bottom part of the backflow preventer unscrewed. This is the end the hose threads onto and the end with the washer.
    How do I remove the other end of the backflow preventer - the end actually threaded onto the hose bib which enters the house?
    There appears to be a tiny hole inside - would there be a small screw holding it on?
    Thanks for the assistance!
    6
    Default Re: Remove backflow preventer
    hi,you can not remove this type of backflow(easily)the hole you see is where there is a set screw that is designed to break off upon tightning,it is possible to back this off by grabbing it w/pliers or vice grips and simultaniously pully down and unscrewing,not sure if your handy enough,might be easier to replace sillcock,but do yourself a favor and buy a new backflow to reinstall...its required...maybe just dont tighten set screw
