    Suburb Chicago
    28
    Cool Covering Drain Pipe
    I am remodeling my basement. I have a 6" Plasic waste pipe on the outside of my new drywall. Pipe was installed after drywall put up. It is about 2 feet from floor and 5 1/2 feet from ceiling. It extends out 6 inches from wall. What is the best way to conceil it and what size lumber should I use ? Thanks
    6,103
    Default Re: Covering Drain Pipe
    It sounds like you are describing a clean-out to me. I would just make a false front cabinet with an open back to slid over it. That way it can easily be moved to gain access.
    Suburb Chicago
    28
    Sorry didn't give enough inoformation. The pipe also runs 11 feet horizontally to floor and ceiling. Thanks for your reply though
