    11
    Default Shower "Hardware" Replacement
    Hello,
    I've scoured the TOH boards to see if I could get an answer, because quite honestly I was afraid that this may be a stupid question, but here it goes...
    I'm doing a budget remodel of my bathroom (1987), and one thing I'd like to do is upgrade the chrome shower hardware. Specifically I'm looking to replace the faucet handle, wall flange, shower head, and stem (not sure if these are the correct terms). Is this something that requires a plumber, or is it just like replacing a shower head (screw off & screw on)? I've also heard of something called replacing the shower valves, which I know can cost $500+. Is this the same thing?
    Thanks!
    8,046
    Default Re: Shower "Hardware" Replacement
    You can replace the handles and wall plate (escutcheon ) on most shower fixtures. You'll need to go to a plumbing supplier or the manufacturer for the parts. You do not need to replace the valve (inside the wall ) to replace the visible parts. The manufacturer's website should have an exploded view of the parts with part numbers to aid in your search.
