    Cool Looking for an adjustable Deck Mount shower for vintage tub
    I have a vintage tub without a shower. I am looking for a cheap(ish) Deck Mount faucet and showerhead - preferably something without the flexible hose type shower head. There is no wall at that end of the tub, so I'd need the hower head support to be attached to the ceiling. The tough part is that I need the mount to be adjustable up to approximately 12" - the openings are a tad over 11".
    Where can I find such a specific item on the web? Or would I have to have a plumber make something from misc. parts?
    Also, the overflow drain is mounted VERY LOW (just 6") from the bottom of the tub. Is there an attachment I can buy like an L-shaped pipe that could raise the level?
ID:	3133   Click image for larger version.
    Dec 2009
    Casper, Wyoming
    159
    Default Re: Looking for an adjustable Deck Mount shower for vintage tub
    Have you tried vinatagetubandbath.com? It looks like they may have what you need. Good luck!
    ________
    Find local plumbers in your area.
    1,383
    If it must be adjustable, there is going to be a flex hose.
    S_M
