    Default Noisy water heater
    I have a whirlpool gas water heater that I installed in 2005. I've had many problems with it and have replaced the thermocouple and thermostat twice.
    After the last time I drained it to change the thermostat it has banged and rumbled while it is running. It only does it when the burner is on.
    Any thought would be helpful.
    Thanks
    163
    Default Re: Noisy water heater
    Check out the thread started by rhuffman on 1/16/2010.
    You probably have the same problem.
