Thread: Aluminium wire
    Portland, OR
    9
    Default Aluminium wire
    How do I tell if I have aluminium wire?
    What are the pros & cons of aluminum wire?
    Thanks for your help!
    MN
    455
    Default Re: Aluminium wire
    Maybe this helps http://www.inspectapedia.com/aluminum/recogniz.htm
    There is plenty of stuff on the internet.
    Dec 2009
    Alpharetta, Ga
    55
    The best place to look is your electrical panel which is the source of all the circuits in your home. Look where the wires terminate into the breakers and lugs where the wire is bare. The copper wire will look like copper (orangest to brown) and the aluminium wire will look like aluminium (shiny metal to gray). Most homes are wired in copper for the branch circuits and aluminium for the main line coming into the house.
    5,836
    One consideration is the age of the house, if it was built after 1972 chances are you have copper wiring.
    Aluminum wiring is OK providing the proper connectors and devices are used and any work is done by someone qualified and familiar with aluminum wiring practices.
