    Jun 2009
    dundalk, MD.
    6
    Default water base or electric base heat
    which is cheaper. water base heat or electric base heat
    Wisconsin
    80
    Default Re: water base or electric base heat
    Hello, Definitely water base heat, that is if you already have a Boiler/Heater etc for set up. Electric is cheaper to install but cost more to run and not as efficient. Hope this helps. GregC
    Hidden Content GregC, President/Founder of Hidden Content
