Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Feb 2012
    92
    Default Re: Sand/Grit from hot water faucits
    You want the real solution is simple you need a whole home carbon filtration back to back with a softener the problem will be solved as another person stated as the sediment/sand builds up in the bottom of the hot water and you turn it on it swirls around and out of the hot tap as to were the cold the sand sediment does not contain as much and is not as noticeable.
    Orem Benjamin Plumbing
    153 N Garden Park Orem UT, Orem, UT 84057
    (801) 960-1565 ‎ http://www.benfranklinplumbingorem.com
  2. #12
    1,565
    Have you checked for a leak? Turn off all faucets, then look at the water meter. Look closely at the little red triangle: if it's turning at all, you have a leak.
    As the water flows across the leak, it can actually create a suction (venturi effect), drawing in sediment. Yes, even on a pressurized line.
