Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
  1. #11
    8,045
    Default Re: Relocating forced air ducts
    I would have to disagree.
    The dispersion of the supply will be severly disrupted by having the return in close proximity. You'll end up sucking supply air into the return before it has a chance to effectively disperse and reducing the heat performance.
    It's not based on tradition but rather dynamics of air flow.
    I would also further the comment that the under window heat/ac units commonly found at hotels that rdsigns refers to, draw the return air from the bottom while spewing the supply air out the top, creating a circular airflow. AT least the unit's that I've seen do.
  2. #12
    Jul 2009
    Northeast
    661
    I have to agree with Canuck, you never put a supply and a return on the same wall.
    My two cents
  3. #13
    Jul 2009
    Northeast
    661
    I'd have to agree with A.Spruce also
  4. #14
    Yep --- I spend enough time in hotels and those A/C / heaters are crappy for air flow.
  5. #15
    8,045
    Quote Originally Posted by Sten View Post
    That's a darned good thing ...
  6. #16
    Jul 2009
    Northeast
    661
    Quote from Rdesigns
    Remember that the supplies drive the system; their velocity throws air out in a pattern that is determined by the configuration of the register, and the function of the return is actually nothing more than pressure relief of total volume of air that the supply builds up.
    HUH??
    In order to properly heat a room you have to get the cold air out, otherwise your just dumping warm air on cold and not getting the proper heating your looking for.
    The same goes for dumping cold air on warm with A/C, you have to get the warm air out, only other difference is you have dehumidification as the warm air is pulled back. The pressure relief is definitely a factor but not the "nothing more than" that you talk of by a long shot.
  7. #17
    Jul 2009
    Northeast
    661
    Why not locate your furnace in the attic, that would solve all your problems. There would be no carrying stick to get in the way and you could put your supplies towards the outside wall and your returns towards the inside wall.
    If that's not an option then they do run ductwork on outside walls, but it is always insulated. It's not the best way but it is done quite often, unless you have closets you can use. Good Luck!!!
    Oh Yeah, seal your ductwork also, LOL
  8. #18
    Jul 2009
    Northeast
    661
    Quote Originally Posted by a. Spruce View Post
    that's a darned good thing ...
    lololol
  9. #19
    Oh geez drag it out .
  10. #20
    Jul 2009
    Northeast
    661
    Nuff said on that subject
