    Oct 2009
    7
    Default Header size for 8 ft closet opening
    I'm framing a closet into a bedroom that will have an 8 foot opening for sliding doors. Since it's not load bearing, I would normally nail 2 2x4's together for the header over this opening, but thought I'd ask here to see if something larger should be used since the opening is so wide.
    Default Re: Header size for 8 ft closet opening
    should be fine for a non load bearing wall.
    If the doors are going to be heavy and hung from the header then you can skin each side of the header with 1/4" or thicker plywood to tie it all together. Otherwise, just a framed header will suffice.
