Results 1 to 10 of 13
    California
    Wink convert old master closet into a laundry room
    We are converting our old master bedroom closet into a laundry room. The main wall shares the master bath sinks on the other side. So there is plumbing and drainage that we can add on to? I am not sure where to start? The electrical is taken care of. Plumbing seems so overwhelming. Is it possible?
    7,602
    Default Re: convert old master closet into a laundry room
    Yes, it is possible, but it's not as easy as just tapping into the vanity drains. The biggest problem is that the vanity drains are smaller than what the laundry drain should be. I believe there is also an issue with having other fixtures plumbed into the laundry drain, it has to be it's own entity.
    What I would recommend is consulting with both an electrician and a plumber to come and assess the needs of the laundry room and give you estimates on what it will take to do the job. It can be done, but not quite as easily as you're thinking.
    163
    IF the drain that serves the MB sinks is a 2-inch line, then you could cut in a 2" tee BELOW the tee(s) that serve the sinks. The new tee must be in the VERTICAL portion of the existing drain line, and above the floor level.
    This new tee will be the start of a trap arm that runs to the p-trap that will serve the new washer standpipe. Be aware that there is a limit on the length of the new trap arm. It should not be over 60". (Some plumbing codes allow up to 8 feet, but you would be safe with 60" or less.)
    Perhaps you might consider contacting the building department to also inquire about the need for a floor drain to be installed for this laundry area.
    Sep 2009
    florida
    598
    I would put a floor drain in even if it not Code, It can be a blessing if you get a water break. You may want to consider installing a trap primer also, at times traps dry out. You dont want the room smelling like theres a dead animal in there lol
    http://www.accentshopping.com/product.asp?P_ID=153836
    Gizmo
    Hidden Content
    Hidden Content
    California
    Post Re: convert old master closet into a laundry room
    Thanks for the great advice. I contacted two plumbers and received proposals of $650.00. I think I may be doing the work myself with some good research. I am comfortable about the drain work it is the water valves that I am not quite sure of. We live in a single story home. The valves run parallel in the wall up to the ceiling and around a door next to the sink.
    7,602
    IMHO, water lines are easier to deal with than drains and venting, so if you're up to the challenge of the drains, Unless you've got galvanized pipes, you can more than handle the supply lines too.
    163
    Are the pipes copper, galvanized, PEX, or what?
    California
    The water lines are copper.
    163
    Quote Originally Posted by Jillsilva View Post
    Then you can use "Sharkbite" fittings to make your connections.
    They're expensive, but easy to use; you just push the fitting over the cut ends of the pipe. You won't need more than a handful of fittings, and the expense will be far less than hiring a plumber.
