    Oct 2008
    11
    Default Replacing Herringbone Struts
    I have a 120 year old house that has Herringbone struts between the floor joists in the basement. Many of the struts have been removed and I want to replace them, but can't figure out a good way to do it between joists where plumbing has been run.
    1,386
    Default Re: Replacing Herringbone Struts
    Hi,
    Well, you're right, if obstructed, they can't be replaced. They are called cross-bracing or x-bridging. Nowadays we use solid blocking, or metal x-bridging. The whole purpose is to prevent deep joists from twisting under load. So, if your joists are less than 2x10's they are of almost no value. If your joists are 2x10's or 12's, you can get the same benefit by attaching strips of furring to the bottom of the joists in the center of each span. That way, no single joist can twist alone.
    S_M
