    Topeka, Ks
    Default Missing Ground Rod
    We had a contractor dig out a basement wall and straighten it. In the process he removed the ground rod along with the copper wire.
    We can drive a new one in but are unsure where the best place to attach it to in the house? Where should we connect a new copper wire from the rod to the house system?
    Default Re: Missing Ground Rod
    To the electrical panel
    6,097
    To the ground bus in the main panel and it should be continuous, no splices.
    Shamokin, Pa.
    645
    Quote Originally Posted by smercer48 View Post
    In my opinion, the contractor should reinstall the ground wire. But that is just me....
    Dec 2009
    Alpharetta, Ga
    55
    Was the ground wire attached to ground rods or to the rebar in the wall?
