Results 1 to 8 of 8
    Nov 2009
    18
    Default Ignition problem on boiler
    My boiler throws its breaker all the time (the one on the igniter unit). I typically have to light a piece of paper to get it to fire. Once it fires up it burns normally. Is this typically a problem with the nozzle not being clean or should I replace the igniter unit? Is that tough to replace?
    Thanks for any suggestions,
    Stuart
    550
    Default Re: Ignition problem on boiler
    Stuart:
    This is usually due to a short in the high voltage coil that creates a spark to ignite the oil.
    Could you re-adjust your personal account so that you can receive personal messages---I'll give you a list of instructions if you want to try to repair this yourself.
    Nov 2009
    18
    I think I updated my account to allow private messages.
    This is the unit I keep hitting the reset on:
    http://www.climatedoctors.com/items/...?itemid=429817
    550
    PM successfully issued.
    Nov 2009
    18
    Nashua,
    I am new to the PM service so I wanted to let you know I sent you a message.
    -Stuart
    PS: Thanks for the help.
    Jul 2009
    Northeast
    661
    Hey NashuaTech, are you telling secrets LOL ?
    Nov 2009
    18
    Nashua,
    Thanks again for your guidance. Your analysis was spot on. After your assistance in diagnosing the high voltage transformer as the culprit, I located and replaced it with a new one. Now my furnace fires up really fast without a lot of fuel being sprayed into the boiler. This makes the burn begin nice and smooth. It is operating better than it has in years.
    Thanks again for all your help,
    -Stuart
    Jul 2009
    Northeast
    661
    NashuaTech is the man and I think I speak for all that post to this Forum. I'm not being smoochy smoochy, it's just fact.
