    Default Leveling Concrete
    Could someone please help. Is there any way to level a concrete floor about 1/2 to 2 inches. The space is about 5x15 feet. This space was used as a porch but now is closed in and I would like to cover it with floating hardwood flooring.
    Last edited by hbha3l; 01-12-2010 at 04:47 AM. Reason: More information about project
    Aug 2009
    Ladson,SC
    192
    Default Re: Leveling Concrete
    See if you can find a product called ARDEX K-301
    What is this space, why is it so out of whack, and what is the proposed use/traffic pattern?
    May 2009
    Elyria, Oh.
    246
    Go to one of your local concrete/brick/block supply houses. Some of the larger ready-mix outfits have a showroom with clerks at the counter that are very knowledgeable. There are several different concrete levelers. The most expensive but easiest to use is a self leveling concrete. You mix up the concrete in a barrel or large trash can to the exact portions on the instructions and then pour it on the floor. The concrete self levels. Don't touch it or try to improve on it after you pour it. Mix up more then you think you need and only pour the concrete until the area is leveled. Toxx the rest out or use it somwhere else.
