    Question Frost on walls and windows
    I just went on an walk trough in a house that i would like to buy. However they had the heat turned off. Their is now frost on a lot of the walls and windows. The walls are the old plaster type. What kind of problems can occur once the heat is back on? Also is their anything i can do to prevent them? Oh ya i live in the great state of Minnesota so it gets cold.
    Aug 2009
    Ladson,SC
    192
    Default Re: Frost on walls and windows
    No great damage to the plaster.
    worst possibility is some cracks from expansion, not a big problem.
    The paint will peel and crack.
    Paint will become detatched from the plaster surface.
    If wall paper is over plaster it will roll back at corners and seams.
