    78
    Default Insulating porch ceiling
    I have an enclosed porch on the front of my house with a shed roof (tar roof) that attaches onto my house at about the second story. I live in the mid-Atlantic area where we have both a heating and cooling (A/C) season. I have run heat/ac ducting out to the space. There was no insulation in the ceiling..just exposed ceiling rafters. I'm trying to make the room a 3-season room (that is to say more efficient). I've insulated the floor w/ fiberglass roll. I've also fixed fiberglass roll between the ceiling rafters but I never finished the ceiling..waiting to see what kind of moisture problems I may have. Well of course, the fiberglass insulation has gotten damp and wet on the exposed side to the roof. My question is...How should I insulate this space? I can put in soffit vents..but cannot put in any type of ridge vent because the shed roof butts up to the house? I was going to remove the fiberglass, put in soffit vents, then put a layer of rigid foam insulation on the rafters...and then my finished ceiling (maintaining an airspace between the ceiling/insulation and the roof). I figured a little movement of air in there is better than none at all. Should I install a vapor barrier before placing the rigid foam? Thanks for any suggestions.
    78
    Default Re: Insulating porch ceiling
    No recommendations or comments at all? My first post doesn't seem to be garnering any interest.
    Lightbulb Re: Insulating porch ceiling
    Hi,
    One option you could look into is using spray foam insulation. This way you won't need to install vents and will also provide a very, very good moisture and insulation barrier.
    I've seen kits that you can buy if you wanted to do this yourself. (i.e. enough for a wall or two) but it can be pretty expensive...
    -Dave
    1,383
    Spray foam would be ideal, but then the next thing is the tightness of the windows, then the floor, then the old exterior wall. They are also heat-loss targets. You might think about getting the floor sprayed with foam underneath; it will be much less drafty. Fiberglass is IMHO, worthless in the situation you have in your floor, as the air moves right through it.
    S_M
