Results 1 to 7 of 7
    Unhappy Clogged shower/tub
    I've plunged until my arm hurts and used chemical cleaners which partly cleared the drain because you can hear water running, but it's still way too slow (it's a normally slow running drain but this is ridiculous). Tried the methods listed on this site, to no avail. When i removed the overflow plate the tub stopper linkage would not come up and out. Any suggestions before i resign myself to a plumber?
    Sep 2009
    florida
    598
    Default Re: Clogged shower/tub
    Gizmo
    Hidden Content
    Hidden Content
    I bought a snake, but because of the way the drain is made, it runs straight across and then down, it would only hit the back of the pipe. It wasn't flexible enough to curve down the pipe.
    Sep 2009
    florida
    598
    Try a metal coat hanger.......
    http://www.youtube.com/watch?v=KiaC9cgDgYo
    Gizmo
    Hidden Content
    Hidden Content
    Tried that too, twice. Didn't work.
    Sep 2009
    florida
    598
    How about call the plumber
    Gizmo
    Hidden Content
    Hidden Content
    Dec 2009
    Casper, Wyoming
    159
    I am with Gizmo on this one. You have tried everything. Its time to call the plumber. It is a routine type of service call and hopefully it wont cost you too much.
    __________
    Find local, licensed plumbers in your area.
