    Default Leaking drinpipe connection
    I have a pedestal sink in the bathroom. Where the P-trap connects to the drainpipe in the wall, the connection has a small leak. The end of the drainpipe has no threads. The P-trap pipe slips into the drainpipe. I have been unsuccessful in completely sealing the connection. Been using silicon caulk made for bathrooms. No Luck. Looked liked Uncle Louie was working on it before buying the house. Going nuts!!!!!! Can anyone offer advice.
    Thanks
    7,923
    Default Re: Leaking drinpipe connection
    How old is the house and the sink?
    50's Ranch-Sink came with the house.
    7,923
    It could be lead and oakum or a derivative of the same type of system. Basically, the joint is packed with a fibrous material then sealed with molten lead or solder. I cannot offer a DIY fix for the situation, sorry.
