    Sep 2007
    Western NY
    26
    Default What would you recommend?
    The last thing I have to do to complete my kitchen remodel is to install some crown molding around where my range hood duct goes thru the ceiling.
    I'm torn between using white crown (so that it blends into the ceiling) and using crown that matches the cabinets.
    I've attached pix of the hood and the cabinets. I'd appreciate your thoughts.
Name:	hood-ceiling small.jpg
ID:	3069   Click image for larger version.
Name:	cabinets small.jpg
    6,481
    Default Re: What would you recommend?
    I would use white because you're going up against metal (I assume stainless steel ) and the cabinet molding would look out of place on it.
    If you're really not sure what you want to do, install the cabinet crown and if you don't like it, paint it white to match the ceiling.
    Sep 2009
    florida
    598
    I agree with Spruce,,,,use the white
    Gizmo
    Hidden Content
    Hidden Content
