    May 2009
    Freeport, Maine
    10
    Default Compressing f/g insulation
    If I use fiberglass batts that are thicker by a few inches than the wall space, will I lose insulation value?
    1,387
    Default Re: Compressing f/g insulation
    Howdy yes compression of the fiberglass does reduce its R value. you might consider instead separating the extra from the batts then installing the sized batts.the ca it pulls apart easily.
    6,940
    Yes.
    It is not the insulation that does the work, it is the trapped air inside it.
