    May 2009
    6
    Default no heat into room
    We have a 2 story house built in 1927. It is heated with forced air gas furnace. THe furnace is only a few years old and in very good condition (just serviced a week ago). The 2nd floor is a converted attic. One of the bedrooms is really cold. We thought we just needed to add insulation to the walls (not very much at all), but I was in the room today while the furnace was on and noticed that barely any air was coming through the vent. And, the little air that was coming through the vent was not warm. The vent in the room next door was blowing strong warm air. What should I do to get warm air to come out of this vent?
    Thanks
    Jul 2009
    Northeast
    661
    Default Re: no heat into room
    On your Main Trunk coming off your furnace there are what is called takeoffs, then the supply run comes off of it. Inside the takeoff is a damper, make sure the damper going to that room is opened. If that doesn't work let us know, Good Luck!!!
