    Dec 2009
    Default trimming a baseboard
    i would like to know an easy way to trim the end of a baseboard without damaging the wall or removing the baseboard entirely. i am wanting to install some casing trim around an interior opening and the baseboard needs to be shortened by the width of the casing......thanks for any replies.
    8,043
    Default Re: trimming a baseboard
    A keyhole saw would probably work best.
    http://www.acehardware.com/product/i...ductId=1290071
    6,045
    I would use an oscillating tool like the Dremel MultiMax (about $99 at Home Depot of Lowe's) or the Rockwell Soniccrafter (about $130) or the Fein MultiMaster (about $300)
    Sep 2009
    florida
    598
    Pull saws are great for what you want to do. I would suggest you tape a really thin pcs of cardboard,paper or plastic against the wall to run the saw down. At times I will put a pcs of masking tape on the exposed side of the wood to eliminate any ripping when pulling the saw towards you.
    Take it slow when cutting with any saw...
    http://www.amazon.com/Stanley-20-331...1686453&sr=8-8
    Gizmo
    Hidden Content
    Hidden Content
