Thread: Woodshop walls
    Dec 2009
    Rising Sun, md
    Default Woodshop walls
    I am currently finishing a new woodshop under my detached garage. The walls are currently block. I am using metal studs, insulating, and then will be drywalling the ceiling and walls. My question, is drywall the best material to use, or should I use another material?
    7,592
    Default Re: Woodshop walls
    Drywall is a good choice.
    5,940
    I have drywall in my shop, I then ran a 24" band of 3/4"plywood around the perimeter to attach shelving, tool hanger, bit cabinets , etc.
