    Dec 2009
    Minneapolis, MN
    Default plaster walls with no insulation and cloth wiring
    I have a 1928 stucco home that has the old cloth wiring and no insulation in the walls. I would like to fix both these issues by taking down the walls, rewiring the house, spraying in the foam insulation, and then putting up drywall. I am well known for turning a small project into a very large project so I am seeking some words of wisdom. Am I opening a can of worms that can be done in a more simple fashion or should I take on (or hire someone to take on) the very messy job of pulling out plaster walls and doing both the wiring and insulation at the same time?
    jhill
    102
    Default Re: plaster walls with no insulation and cloth wiring
    See if you can find someone who does foam ins with out having to tear out the walls. A good electrician should be able to rewire with out to much damage to the walls.
