    Dec 2009
    Default Removing Old Chormalox Electric Baseboard Heater
    We have an old Chormalox electric baseboard heater (Model BR 81), 99 inches long in our family room that we want to replace. However, I am having trouble figuring out how to access the wiring so that I can remove the heater. The front cover does not seem to be removable and there is no separate access panel to the wiring box from the front or side of the heater. The wiring is on the right side of the heater. I am unable to determine if I should simply remove the screws holding the heater on the wall and then try to disconnect the wiring from the back of the heater. Your help would be greatly appreciated.
    Sep 2009
    jersey
    174
    Default Re: Removing Old Chormalox Electric Baseboard Heater
    one of the end caps should have a set screw on it to be removed and give access. If your replacing it shut it off and start disassembleing untill you get to it.
    Help us name our new Hidden Content
    Dec 2009
    There are not set screws on the side or other apparent access to the wire box. That's my problem. Any suggestions? Thanks.
    Feb 2009
    693
    There must be a way........ Be a hero and pop the cover off....... You can do it!
