    Dec 2009
    Default Removing Old Chormalox Electric Baseboard Heater
    We have an old Chormalox electric baseboard heater (Model BR 81), 99 inches long in our family room that we want to replace. However, I am having trouble figuring out how to access the wiring so that I can remove the heater. The front cover does not seem to be removable and there is no separate access panel to the wiring box from the front or side of the heater. The wiring is on the right side of the heater. I am unable to determine if I should simply remove the screws holding the heater on the wall and then try to disconnect the wiring from the back of the heater. Your help would be greatly appreciated.
    Jul 2009
    Northeast
    661
    Default Re: Removing Old Chormalox Electric Baseboard Heater
    If I were you I'd talk to an Electrician, 110 will hurt, 240 will kill you. Maybe NEC will stop by and help you out. Good Luck!!!
