Thread: steam heat
    Apr 2008
    Smile steam heat
    hi i would like to know how to size radiator for bedroom my heating is steam.
    443
    Default Re: steam heat
    mussey:
    You would have to first get the heat loss calculation of the room (how many btu's/hour are oozing out of it on a cold day) by doing one of the free heat loss calculations below.
    You would then obtain a radiator that has a similar heat loss.
    Usually the EDR (equivalent direct radiation) of the radiator is obtained (see sites below), then the HLC is obtained from that.
    If you have to buy a radiator, try the Yellow Pages for a used plumbing supply house, demolition co. or Salvage Yard.
    http://www.bgmsupply.com/calculateheatloss.asp
    http://hearth.com/calc/roomcalc.html
    http://www.colonialsupply.com/resources/radiator3.htm
    http://www.antiqueplumbingandradiators.com/askpage.html
