    Apr 2008
    Default Repiping the house
    I called the plumber out this morning to
    replace my water heater. The thing was
    leaking all over the garage. The only
    problem was that it isn't the water heater.
    There is a leak in the copper plumbing of
    this old (26 years) house. We've got a
    concrete slab foundation - the leak is
    somewhere in there.
    The plumber said he could jack hammer up the
    kitchen floor trying to find the leak, patch
    it, and then we could wait for another leak
    to appear some day or we could repipe the
    whole house through the crawl space. Either
    way, I'm suddenly faced with several thousand
    dollar expense.
    My questions are:
    does copper piping really go bad like that?
    are there other options?
    how hard is the repiping option?
    Thanks,
    ofs
    Lakeland ,MN
    356
    Default Re: Repiping the house
    Copper piping almost last forever in most cases. But copper layed in concrete causes a chemical reaction between the two. The Copper Deteriorates and then leaks. The cheapest way is to re-pipe the home above the slab. As over time the whole system in the concrete will fail in time.I am not a plumber but in my times doing electrical work in homes built with copper in concrete my customers have seen the same thing. Good luck
    Harry
    Apr 2008
    Thanks for the reply. This looks
    like another very expensive
    summer starting. Crap. Now, do
    I pull tuition payments for one of
    my two biggest kids or try and
    sell one of the other five to
    the gypsies?
    ofs
    Wisconsin
    76
    Maybe you can enroll the oldest kids in the trades,i.e. plumbing, electrical, HVAC and then you can have the family discount apply the next time this type of expense rears it's ugly head....
    Memphis, not Egypt
    183
    I've seen 50 year old copper in contact with 50 year old concrete and it was fine. I don't suggest the everyone should do it. You may have a number of problems contributing to the expiration of your water distribution system. Test the pressure if its over 60psi then you ned to reduce it. 40 to 45 operating pressure is ideal. Not exact but in the neighborhood. Test your waters chemical composition for acidity, mineral content etc. Since you are repiping then I recommend PEX. It is way more cost effective to install compared to copper labor wise and material cost. Fact is that the only way copper can compete is in the "pretty" factor. Besides If it failed already then where is the assurance that it won't again. Personally I think its the ground clamps that the electricians and Phone people put on the copper and that it allows electrolisys. Dogone Sparkys haha
    Apr 2008
    I got a second opinion. Instead
    of a complete repiping of the house,
    this plumber will access the leak from
    the garage, patch the pipe, patch
    the concrete, and be outta there for
    about 6K less than the other guy.
    If I should continue to get leaks,
    then I'll have to start thinking
    about which kid to unload.
    ofs
