    Dec 2009
    Question air in hot water line
    Can an electric hot water tank create air the lines ? We have a two story house built in 2001, with a well. Several months ago I noticed air coming from faucets when turned on. I had a well company check the pump ,no problems. I also replaced all toilet componets & pressuer tank. It's more noticable on the hot water line. The hot water tank was replaced before the problem started.
    69
    Default Re: air in hot water line
    It sounds like there is still some air trapped somewhere in the lines. Have you tried running every one of the hot water faucets, to see if air comes out of every one? Start at the end of the hot water line. By doing this, the air , hopefully will all move to that last faucet.
    Good luck, and have a Jolly Christmas.
    OKC
    247
    I had the same problem, i hooked a hose up to the tank and let it run for 5 minutes or so. it seemed to help.
    HOPE THIS IS HELPFUL!
    Oklahoma City, OK
    6,047
    This can also be caused by a faulty faucet washer. When you turn the water on at one faucet it sucks air in the faulty one.
    Dec 2009
    Thank you for your sugestion, I have tried that. We have a garden tub that is used every morning. I would think that any air trapped, would have escaped after 9 months.
    Mar 2010
    When you have high water pressure the water heater adds to it with expansion. Before we get into this, are you on city or well water?it makes a big difference. let me have more info before making an answer.
    Find out all latest update in Hidden Content . If you are studying for your Hidden Content . Create and take notes on any Hidden Content
