    Apr 2008
    Default Back Roll Exterior?
    We have a 8 yr old house with a stucco front with wood siding elsewhere. Got several painting quotes from recommended and/or highly rated firms. All apply 2 spray coats, 1 back rolls after each coat. While the back rolling company isn't the highest it is almost 20/25% higher than the most recommended one. What are the arguments to having it back rolled? Thanks - Roy
    7,913
    Default Re: Back Roll Exterior?
    This is the reason for back rolling. Rough textured surfaces don't accept sprayed coatings too well, the coating tends to pool on the high points of the surface. Back rolling collects that surface pooling and forces it down into the crevices, minimizing shadows and such. Now, an experienced painter can minimize shadowing and surface pooling by applying the paint in a particular manner, in many cases eliminating the need for back rolling.
    To try to help you narrow your choices, if all things were equal I'd go with the company that is offering the back rolling. Because this company's bid is higher than what would seem to be your preferred contractor, then I would ask for references from both companies that have done to jobs similar to yours that you could go and inspect personally. From those inspections I would choose the better workmanship.
