    Apr 2008
    Default Half bath wallboard/sheetrock/drywall
    I am redoing our half bath (toilet and sink) and am curious about what drywall I am allowed to use, per code.
    More specifically, I have a ton of regular paper-faced drywall that I'd love to use, but don't want to be in any form of violation by doing so.
    I understand in a typical bath with shower/tub that there are restrictions to use either green board or the new paperless drywall, but I don't know if any of these apply in a half bath. I certainly can't envision enough moisture in there to mandate special wallboard.
    This probably isn't a local issue, but in case it is, I am in Atlanta Georgia.
    Thanks!
    J. Walker
    Wisconsin
    76
    Default Re: Half bath wallboard/sheetrock/drywall
    In my opinion, the drywall you have should be fine. Since it is only a half bath with a toilet and sink you should have very little moisture.
    Chicago, IL
    162
    In a situation like this, we usually just use one sheet of moisture-resistant (green) drywall on the bottom 4' of the wet wall. Everything else just gets regular drywall.
    HTH
    Dave
