    Apr 2008
    32
    Default Help with marker removal
    Hi all:
    I have a wooden wine case (unfinished oak) that I'd like to stain/dye. Unfortunately, someone marked up the top face of the case's lid with a sharpie or other permanent marker. Is there a way to remove most of this without damaging the wood or affecting its ability to accept stain? I've tried sanding it down; no luck.
    Denver, CO
    666
    Default Re: Help with marker removal
    Wonder if you have tried denatured alcohol?
    Apr 2008
    32
    Quote Originally Posted by kentvw View Post
    I have not, but that's what I'm thinking may be the way to go. Thanks!
    1,131
    And/or......lacquer thinner.
    that mr.clean miracle sponge works wicked good but im not sure if it will do anything to the wood, id look into it....
    Lily Dale, NY
    14
    I would "wet sand" the cabinet top with the stain you are going to use...maybe a 150 to 220 grit...
    The stain along with the sanding should get the marker out...
    If not.. Then I would "wet sand" some type of thinner..
    Try to re-create this on another board and see what works...
    I almost always wet sand stain.. It cleans the wood...
    Shamokin, Pa.
    645
    WD-40 is an excellent spot remover. Test it first though.
