    Dec 2009
    Default Space between flooring
    What is recommended to fill approx. 1/16" to 1/8" space between boards? Matching wood filler? Remove board and replace with new?
    Except that boards are glued to conc. And fit into each other with t&g. Floor expert would have to do that.
    5,836
    Default Re: Space between flooring
    Twin or small rope is the traditional way to fill the cracks.
