    Apr 2008
    Default bisquit tub what color tile?
    We just put in a Kohler bisquit color tub. What color tile goes with bisquit? Need help fast. This project has been on going for 1 1/2 yrs!
    Apr 2008
    Default Re: bisquit tub what color tile?
    Hello,
    I would use the same color biscuit (ivory) 4"x4" squares (glossy)... Good Luck.
    8,065
    Gravy goes well with biscuit.
    Every tile manufacturer has their own color names. Home Depot's economy line is Dal Tile and they have an "almond" that will probably be a close match to your biscuit. Oddly enough, Home Depot also carries Kohler products, so you can take a sample of tile from the tile aisle and match it up to Kohlers color. Another method would be to get a Kohler brochure for the color, then go to a tile supplier and have a look at all the offerings, you may find a different type and style of tile that will look better.
    You could also try an ****** search.
    http://daltileproducts.com/catalog.cfm?rm=4
    Oct 2007
    132
    Honey or jam also go well with biscuits...
    What's your color scheme? And it really depends on what color you want to look at in that bathroom... with the neutral of the biscuit color (what ever happened to beige, cream, brown, yellow... things like that...?) just about anything will go. The light colors if you want a monochromatic, or add something deep and rich in color or even bright. just maybe not the whole room.
    A trip to a couple bath showrooms might be fun, too.
