Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
    Apr 2008
    Red face Cost to completely rewire an old house?? Is it worth it?
    I'm looking at buying a 1901 Victorian home. The seller is offering it "as is, where is, etc....The electricity was turned of in this home a year ago. I'm told that it needs to be brought up to code. All of the wiring is running through conduit pipe. The house is about 3700 square feet w/3 stories. The owner (who is an electrician that lives in another state) says it can be replaced for about $3000. I've talked to some contractors....they say at the very least $16,000, but probably closer to $30,000. My question is...Who is taking me for a ride? The owner or the contractor? Is anyone out there that has faced similiar problems?
    Default Re: Cost to completely rewire an old house?? Is it worth it?
    I'm guessing the service panel will likely need replacing as well and there's no indication as to the condition of the mast and meter box and if the service will be upgraded from 60 -100 or 200 amp service.
    It's impossible to tell over the internet what's involved for your home.
    However .... I would have to say if the entire home needs to be rewired then ask the seller to do it and you will give him $3000 more for the home.
    I would have to guess it will be closer to the $16k + mark than the $3k mark if the entire house has to be redone.
    It would probably be about a weeks worth with 2 guys doing 3 floors ... 4 if you have a basement.
    Just my 2 cents worth.
    612
    I also think the price would have to be closer to $16k rather than $3k for a whole house rewire. I would suggest someone local do it rather than getting the owner who lives in a different state (even though he is an electrician). Obviously there are many other issues (roof, plumbing, heating, insulation, foundation, etc, etc.) to consider when buying a house like this, but I would make this upgrade part of the current contract and figure the cost as a negotiation to the current price of the house. That way it gets done to code and inspected, but you don't have to be the one GC'ing the work. Make sure you know what condition the walls will be in when they are done. Adding the additional circuits & fixtures(i.e. hardwired smoke & CO detectors) to bring it up to code will probably mean cutting into the walls. That could figure into the cost adder you would be willing to pay.
    One thing to double check, if you haven't already, see if any permits for work have been pulled for this "as is" house and if the permits/inspections match up with any improvements already done.
    Also, ask if there is a domino effect on improvements. What I mean by that is some municipalities will say that if you improve 50% (or fill in the percentage) of a house than all systems and construction must be brought up to code. They get to determine what is meant by 50% and that could change based on which inspector is on the job. A flip we did once taught me this the hard way after the initial AHJ left the municipality and the replacement didn't quite agree on his predecessors decisions. This caused me to have to reconstruct a pre existing set of steps to give an extra 2" of headroom. This happened at the end of a remodel which made a new header necessary in a room that already had all new paint and carpet. I ate some Tums the day I found that out!
    GL on the project.
    Apr 2008
    Binghamton, NY
    20
    Nice response BP..this is some great information. Im looking into doing some rewiring also. Good luck as well!
    New homeowner in need of Hidden Content assistance.
    Apr 2008
    North Carolina
    There is no way the cost will be $3,000 unless you are doing it yourself. You will pay at least $3,000 in materials cost. Even at $16,000+ it is worth it though. I would do it in a heartbeat, since you have everything running in conduit. That's an electrician's dream!
    Blessings on your project!
    Lakeland ,MN
    356
    Before you say everything is in conduit I would suggest you check that out. What I have found is that when old homes in that time frame had gas light fixtures. When the house was wired the first time the gas pipe was used to pull wires to the new lights. What you might have is old gas pipe. The fittings in gas pipe are close 90 degree bends. almost impossible to pull wires through. Besides to bring it up to code it would be illegal to use it. 16k does not seem out of line to rewire an old large house like yours
    Shamokin, Pa.
    645
    A house with conduit. Unheard of in my neck of the woods.
    That would be very interesting to see.
    Lakeland ,MN
    356
    Ernie chicago and all of the burbs require conduit in all electrical installations. Including residential Type NM cable (romex) is strictly prohibited). First time I saw that I couldn't believe it
    Shamokin, Pa.
    645
    Quote Originally Posted by Ravens53 View Post
    ***, that must keep a lot of Sparkies on the job.
    What is the reasoning behind it?
    Its not like Romex is unsafe and all that.
    9
    I have rewired alot of older homes over the years. And alot of people that want to rewire their homes some can afford to do the entire house at one time and many of these home owners could not afford to rewire their house all at one time. So some of them rewire there houses in stages. Like you start with the main panel build your new service and start with rewiring 1 or 2 rooms at a time. If you are wiring it with #12 awg wire put these on 20amp single pole breakers. And on the rooms that has the older wire in them. The ones that you haven't rewired yet if the wire is still in good shape derate these wires and put them on 15amp breakers. Just an idea hope this helps. And on the question is it worth rewiring this house that depends on how much you like this house.Good luck
